[OpenLayers-Trac] [OpenLayers] #3597: OpenLayers.Layer.WMS options - id field
OpenLayers trac-20090302 at openlayers.org
Mon Dec 12 11:27:26 EST 2011
 Reporter:  fvigetti   |       Owner:  euzuro
     Type:  bug        |      Status:  new
 Priority:  blocker    |   Milestone:  2.11 Release
Component:  Layer.WMS  |     Version:  2.11
 Keywords:  options    |       State:  Commit
 I need to use the id field of the options object when I add a layer, to
 easily retrive the layer object through the API getLayer, but I verified
 with Firebug that this id is not effectively stored anywhere. The test of
 this is that when I call getLayer using this id, I receive a null object.
 Similarly to this, when I use OpenLayers.Layer.WMS.Post to add a layer,
 setting the id field in the options object gives me in runtime the
 following error:
 Uncaught TypeError: Cannot call method 'addEventType' of null
 OpenLayers.Layer.Grid.OpenLayers.Class.initializeOpenLayers.js:1059
 OpenLayers.Layer.WMS.OpenLayers.Class.initializeOpenLayers.js:1583
 OpenLayers.Layer.WMS.Post.OpenLayers.Class.initializeOpenLayers.js:2689
 addLayerfao-widgets-map-js-0.1.js:185
 initMapindex.html:32
 dispatchEventfao-commons-0.1.js:46
 loadfao-widgets-map-js-0.1.js:76
 initindex.html:21
 (anonymous function)index.html:71
 onload
 Could you please give me some clarifications for this behaviour? And if I
 do something wrong?
 Thanks in advance
 Francesca
Ticket URL: <http://trac.openlayers.org/ticket/3597>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
