[OpenLayers-Trac] Re: [OpenLayers] #3066: unit tests should work with a build js file optionaly
OpenLayers trac-20090302 at openlayers.org
Mon Feb 21 04:28:11 EST 2011
 Reporter:  pgiraud  |       Owner:
     Type:  feature  |      Status:  new
 Priority:  minor    |   Milestone:  2.11 Release
Component:  general  |     Version:  2.10
 Keywords:           |       State:
Comment(by pgiraud):
 So attached is a patch which gives the opportunity to add '?mode=build' in
 the 'run-tests.html' url so that we can use the built library. It is
 supposed to be in the build directory.
 Please review.
Ticket URL: <http://trac.openlayers.org/ticket/3066#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
