[OpenLayers-Trac] [OpenLayers] #3074: Manual test "multiple-google-layers.html" fails (resizing issues)
OpenLayers trac-20090302 at openlayers.org
Mon Feb 21 06:46:36 EST 2011
 Reporter:  marcjansen    |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  minor         |   Milestone:  2.11 Release
Component:  Layer.Google  |     Version:  2.10
 Keywords:                |       State:
 In the file /tests/manual/multiple-google-layers.html the instructions for
 testing resizing are:
 "Resizing a map (by resizing the browser window) and then changing base
 layer works well. That is, the center & scale are preserved and all tiles
 are well aligned."
 This doesn't work for me as expected. Steps to reproduce
   * add a Google layer to map 2
   * make the selected layer the baselayer via layerswitcher
   * zoom to a specific region
   * make "Dummy Layer" the baselayer again
   * resize the browser window
   * change to the google layer as baselayer
 This test uses version two of the Google API, so maybe this is related
 somehow.
 This might be related to the failing tests in #3066
Ticket URL: <http://trac.openlayers.org/ticket/3074>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
