[OpenLayers-Trac] Re: [OpenLayers] #3103: Tap property of Click Handler, Control.Navigation center-on-tap
OpenLayers trac-20090302 at openlayers.org
Fri Feb 25 03:44:16 EST 2011
 Reporter:  crschmidt           |       Owner:
     Type:  feature             |      Status:  new
 Priority:  major               |   Milestone:  2.11 Release
Component:  Control.Navigation  |     Version:  2.10
 Keywords:  mobile              |       State:  Review
Comment(by bartvde):
 Hey Chris, a few comments but overall this looks good:
  * APIProprety (typo, 2 occurrences in patch)
  * handleClick in Navigation.js: should be this.map instead of map (2
 occurrences)
  * TouchNavigation.js: defaultClick: this.map instead of map
  * should the comment on how to disable this behaviour not also make it
 into TouchNavigation?
  * after tapTolerance there is an extra white line
  * firstMouseOver not documented as a property
  * then unregister to save processing on further mousemoves -> should this
 not say mouseovers?
 One question I have is wrt to the default, should this behaviour not be
 false by default in Navigation and true by default in TouchNavigation? I
 am not sure if people would actually be using Navigation instead of
 TouchNavigation if they want to target mobile development? But this is
 more of a question than a concern overall.
Ticket URL: <http://trac.openlayers.org/ticket/3103#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
