[OpenLayers-Trac] Re: [OpenLayers] #3060: SingleFile.js - Improvement of RegExp in _getScriptLocation function
OpenLayers trac-20090302 at openlayers.org
Fri Feb 25 15:09:41 EST 2011
  Reporter:  neumann  |       Owner:
      Type:  feature  |      Status:  closed
  Priority:  minor    |   Milestone:  2.11 Release
 Component:  general  |     Version:  2.10
Resolution:  wontfix  |    Keywords:
     State:           |
Changes (by crschmidt):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 There are only two pieces of code which depend on scriptLocation. These
 are:
  1. OpenLayers.ImgPath
  2. Automatic addition of themes to the DOM.
 The latter is not the ideal way to include themes in your page: You should
 instead set the theme: null option on your map, and include the CSS
 manually, like:
   <link rel="stylesheet" href="theme/default/style.css" type="text/css" />
 (This is highly recommended for all applications.)
 For the former problem (OpenLayers.ImgPath), you can set
 OpenLayers.ImgPath = "/my/path/to/images/", pointing to a directory which
 contains the contents of the OpenLayers 'img' directory.
 Rather than adding a new hack for every potential naming scheme that comes
 long, I highly recommend using these two methods to cause your script to
 not care about whether getScriptLocation is correct or not. As an
 alternative, you can modify the _getScriptLocation function:
   OpenLayers._getScriptLocation() { return "/my/path/"; }
 But I do not recommend this over the previous option.
Ticket URL: <http://trac.openlayers.org/ticket/3060#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
