[OpenLayers-Trac] [OpenLayers] #3148: SingleTile & Base Layer
(WMS?) Bug
trac-20090302 at openlayers.org
Thu Mar 3 11:08:01 EST 2011
#3148: SingleTile & Base Layer (WMS?) Bug
Reporter: javivivi | Owner:
Type: bug | Status: new
Priority: minor | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
You can see it in this example page:
http://openlayers.org/dev/examples/single-tile.html
Follow this steps:[[BR]]
1.Maximize Layer Switcher. You'll see Single Tile layer[[BR]]
2.Change to "Multiple Tiles" Layer[[BR]]
3.Pan/Move the layer a bit, for example, put Spain in the center of the
map.[[BR]]
4.Change to "Single Tile" Layer, and... you'll see that shows the previous
loaded image from the layer, and then, when its loaded, it shows the
correct image.
But this creates a very strange effect.[[BR]]
I've made some tests and I noticed that only happens
if you have a WMS Base Layer (not happens if overlay) with singleTile =
true.
It happens in OpenLayers 2.10 and trunk version, but NOT in 2.9.1, 2.9 or
2.8.
I haven't tested other versions.
It happens with Google layers too, for example, if you have a WMS Base
Layer (singleTile) and a Google Layer
Do you think this is easy to solve?
Thank you, and sorry about my english :(
Ticket URL: <http://trac.openlayers.org/ticket/3148>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
