[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Tue Mar 8 02:19:48 EST 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Needs More Work
Changes (by erilem):
  * state:  Review => Needs More Work
Comment:
 Replying to [comment:6 adube]:
 > I set the State for this ticket to Review.  Two things are remaining to
 think for now :
 >  * should an added feature with a state != null trigger the
 "featurestatechanged" event ?
 I don't think so. The user can listen to {{{featureadded}}} and take
 appropriate action if the feature state is set.
 >  * should the feature be redrawn or should that be left to do on client-
 side (for example, using the toState("delete") on del key pressed using
 the ModifyFeature control, should the feature be redrawn) ?
 I would leave that to the application developper.
 Your patch looks good. I'll do a more thorough review when time permits.
 I'm setting the ticket state to Needs More Work as the current patch
 doesn't include tests.
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
