[OpenLayers-Trac] Re: [OpenLayers] #3158: "build.py -c closure" does not work on Windows systems.
OpenLayers trac-20090302 at openlayers.org
Sat Mar 12 17:41:45 EST 2011
 Reporter:  jorix                                 |       Owner:
     Type:  bug                                   |      Status:  new
 Priority:  major                                 |   Milestone:  2.11 Release
Component:  general                               |     Version:  2.10
 Keywords:  closure compiler undefined variables  |       State:  Review
Changes (by jorix):
  * keywords:  closure compiler => closure compiler undefined variables
  * state:  => Review
Comment:
 The proposed patch attachment:3158.patch has the following
 characteristics:
  * Fixes two bugs described (blanks in the path and execution failure on
 Windows systems due to temporary files) ['''A''']
  * When using {{{python build.py -c closure}}}:
    * Does not allow undefined variables ['''B''']
    * Displays the source file names and line numbers in case of errors or
 warnings ['''C''']
  * When using {{{python build.py -c closure_ws}}}:
    * Makes a pre-compression "jsmin" if the merged code size exceeds
 1000KB ['''D''']
  * Improved console messages on errors ['''E''']
  * The changes have been documented in "README.txt"
 I think it is important to use the compiler's ability to detect
 '''undefined variables''', a sample of this is that in the last week I
 reported '''4 errors''' of this type (see r11663, r11664, r11665 and
 r11702)
 Implementation:
  * It replaces "tools/closure.py" by "[http://code.google.com/p/closure-
 library/source/browse/trunk/closure/bin/build/jscompiler.py
 tools/closure_library_jscompiler.py]" (solves ['''A'''] and required for
 ['''C'''])
  * In "build/build.py" rewrite the treatment of compression options,
 especially for {{{closure}}} and {{{closure_ws}}} (Required for ['''B'''],
 ['''C'''], ['''D'''] and ['''E'''])
  * Creates two new methods in "tools/jsmerge.py" who share common code on
 {{{run}}}:
    * {{{merge}}}: returns merged code (as was {{{run}}} method) but only
 requires two parameters. Used in all compression options except for
 {{{closure}}}.
    * {{{getNames}}}: returns an array with the names of the sources
 resulting from the configuration (Required for ['''C'''])
  * Activate different compiler flags ({{{--externs}}},
 {{{--jscomp_warning}}} & {{{--jscomp_error}}}) only to detect undefined
 variable errors (Required for ['''B'''])
 Tested on Windows and Linux for all compression options.
 Please review
Ticket URL: <http://trac.openlayers.org/ticket/3158#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
