[OpenLayers-Trac] Re: [OpenLayers] #2946: Panel: New icons and new displayClass for use with panels.
OpenLayers trac-20090302 at openlayers.org
Mon Mar 14 19:09:49 EDT 2011
 Reporter:  jorix                         |       Owner:  jorix
     Type:  feature                       |      Status:  new
 Priority:  minor                         |   Milestone:  2.11 Release
Component:  Control.Panel                 |     Version:  2.10
 Keywords:  CSS displayClass Panel icons  |       State:  Needs More Work
Comment(by jorix):
 Replying to [comment:2 marcjansen]:
 > Hi jorix,
 > thanks a lot for your contribution.
 Great! Tomorrow afternoon I start work on this.
 > I have a few remarks:
 >   * When adding {{{.olPanelIconsLeft}}} to the panel, the
 >   controls appear in reversed order which feels strange and unexpected
 to me.
 >   From the name one would expect that only the panel changes the
 position,
 >   right? I suggest renaming the class to e.g.
 {{{.olPanelIconsReversed}}}
 Yes, I agree.
 >   * Could you please update the other examples you mentioned so that
 they look
 >   functional with your patch applied? I only had a look at {{{snap-
 split.html}}}
 >   and that looked broken.
 ok
 >   * It would be great to have the possible CSS-classes documented
 >   in {{{OpenLayers.Control.Panel::initialize()}}}
 I'll try to do it and a link to the example, but my English is bad.
 >   * Do you think it is possible to enhance the styles for the CSS class
 >   {{{olPanelIconsLeft}}} so that the class is a drop in replacement for
 >   {{{.olPanelIcons}}}? Do you see a chance of getting rid of the need to
 add
 >   two classes?
 I agree with the proposal to use only one class  (and as
 {{{.olPanelIconsReversed}}}) I will work on it. But now I'm not sure get
 it, and that CSS is not too dirty.
 > If not, the documentation of
 >   {{{OpenLayers.Control.Panel::initialize()}}} should clearly indicate
 how to
 >   reorder panel items (At least a link to the example would be
 appropriate)
 ok, if I can not do with one class, I will document the use of two
 classes.
 >   * If it is possible, it would be very nice if you could explain the
 >   positioning of the panels in the example with visible CSS-code
 ok
 >   * As you provide a "blank" panel background-image
 >   ({{{olControlItemInactive}}}) you might enhance the example with code
 that
 >   shows how to add simple custom icons using the CSS property
 {{{content}}},
 >   e.g.
 > div.olControlItemInactive:after {
 >     content: "?";
 >     text-align: center;
 >     font-size: 14px;
 >     font-weight: bold;
 >     margin-left: 8px;
 It's interesting. But I think I have a better proposal:
 Months ago I wrote code to create icons '''with text and white
 background''' (on and off) The icons are re sized to the width of the text
 or {{{<img />}}} (using {{{OpenLayers.Util.getRenderedDimensions()}}}).
 It is not published because it depends on #2862 (uses new {{{panelIcon}}}
 property)
 Do you think about this proposal?
 NOTE: The white icon is designed for not filing an icon when not properly
 reported a displayClass in a control.
 >   * You have a typo in the example: it says {{{olPanelIconsVertival}}}
 instead
 >   of {{{olPanelIconsVertical}}} once
 oops! ok
 >   * Could you update the patch so it applies at current trunk?
 Yes, yes!  :-)
Ticket URL: <http://trac.openlayers.org/ticket/2946#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
