[OpenLayers-Trac] Re: [OpenLayers] #2906: Panel: Simplify the method "redraw"
OpenLayers trac-20090302 at openlayers.org
Thu Mar 17 04:05:09 EDT 2011
 Reporter:  jorix          |       Owner:  erilem
     Type:  feature        |      Status:  new
 Priority:  minor          |   Milestone:  2.11 Release
Component:  Control.Panel  |     Version:  2.10
 Keywords:                 |       State:  Review
Comment(by erilem):
 The description of the ticket says "But to activate/deactivate a single
 control is not necessary to rewrite all the icons, just need to change the
 className of div of the icon". I don't think that statement is correct.
 When a control is activated or deactivated the appearance of every control
 is to be changed.
 That being said, I think it makes great sense not to remove/add DOM
 elements multiple times each time a control is activated or deactivated. I
 guess the patch could just involve rewriting redraw like this:
     redraw: function(brutal) {
         if(brutal) {
             for (var l=this.div.childNodes.length, i=l-1; i>=0; i--) {
                 this.div.removeChild(this.div.childNodes[i]);
             this.div.innerHTML = "";
         if (this.active) {
             for (var i=0, len=this.controls.length; i<len; i++) {
                 var element = this.controls[i].panel_div;
                 if (this.controls[i].active) {
                     element.className = this.controls[i].displayClass +
 "ItemActive";
                 } else {
 "ItemInactive";
                 if (brutal) {
                     this.div.appendChild(element);
 and calling {{{redraw(true)}}} where appropriate.
 What do you think?
Ticket URL: <http://trac.openlayers.org/ticket/2906#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
