[OpenLayers-Trac] [OpenLayers] #3190: BBOXSR in ArcGIS93Rest layer
is wrong for non-lon/lat projections
trac-20090302 at openlayers.org
Fri Mar 25 13:32:18 EDT 2011
#3190: BBOXSR in ArcGIS93Rest layer is wrong for non-lon/lat projections
Reporter: jdege | Owner:
Type: feature | Status: new
Priority: major | Milestone: 2.11 Release
Component: Layer.ArcGISCache | Version: 2.10
Keywords: | State:
I was playing with the arcgis93test.html example.
I changed maxExtent, maxResolution, and setCenter to draw a map of
Minnesota only, and everything worked fine. I then changed the projection
from EPSG:4326 to EPSG:26991 – and got a solid black map.
Examining the URLs of the tiles, it became apparent what the problem is:
http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer/export?
LAYERS=show%3A0%2C2&
FORMAT=png&
BBOX=-91.6%2C43.2%2C-88.4%2C46.4&
SIZE=256%2C256&
F=image&
BBOXSR=26991&
IMAGESR=26991
The BBOX is being passed in lon/lat, but the BBOXSR is set to 26991, which
is a meters projection.
If I set BBOXSR=4326 and leave IMAGESR unchanged, the tile draws
correctly.
The problem is in getURL() - bounds.toBBOX() returns coordinates in
Lon/Lat, but newParams always sets BBOXSR to the same srid as IMAGESR, and
that is simply not right.
Either the bounding box being passed has to be transformed to the
projection of the layer, or BBOXSR has to always be passed a lon/lat srid.
Ticket URL: <http://trac.openlayers.org/ticket/3190>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
