[OpenLayers-Trac] [OpenLayers] #3191: maxResolution not correctly set when initializing map from WMC document
OpenLayers trac-20090302 at openlayers.org
Fri Mar 25 14:21:41 EDT 2011
 Reporter:  trondmm      |       Owner:  tschaub
     Type:  bug          |      Status:  new
 Priority:  minor        |   Milestone:  2.11 Release
Component:  Format       |     Version:  SVN
 Keywords:  wmc context  |       State:  Review
 SVN rev. 11727
 When a map object is initialized from a WMC document, maxResolution is not
 set, leaving it at the default 1.40625. If the projection units is not
 degrees, this will cause openlayers to zoom too far in, and it is
 impossible to zoom far enough out to see anything useful.
 The attached patch fixes this.
 Examples:
 without patch:
 http://wms.met.no/wmc/loadwmc_210.html
 with patch
 http://wms.met.no/wmc/loadwmc_dev.html
Ticket URL: <http://trac.openlayers.org/ticket/3191>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
