[OpenLayers-Trac] [OpenLayers] #3214: drawing tools - finishTouchGeometry is useless
OpenLayers trac-20090302 at openlayers.org
Wed Mar 30 08:29:56 EDT 2011
 Reporter:  erilem           |       Owner:  tschaub
     Type:  feature          |      Status:  new
 Priority:  major            |   Milestone:  2.11 Release
Component:  Handler.Polygon  |     Version:  2.10
 Keywords:                   |       State:
 When adding touch support to the drawing handlers we added the
 {{{finishTouchGeometry}}} method to the Path handler. This method is
 useless and redundant with {{{finishGeometry}}}. I think it was introduced
 because of a design issue in the Polygon handler, the latter should indeed
 define {{{finishGeometry}}} and let the Path handler handle double-clicks.
 The patch that will follow will actually suppress code.
Ticket URL: <http://trac.openlayers.org/ticket/3214>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
