[OpenLayers-Trac] Re: [OpenLayers] #3195: Zoom while drawing: Strange behavior of the cursor.
OpenLayers trac-20090302 at openlayers.org
Wed Mar 30 13:41:13 EDT 2011
 Reporter:  jorix         |       Owner:  erilem
     Type:  bug           |      Status:  new
 Priority:  major         |   Milestone:  2.11 Release
Component:  Handler.Path  |     Version:  SVN
 Keywords:                |       State:  Review
Comment(by jorix):
 Replying to [comment:3 erilem]:
 > It would be great if you could investigate this problem.
 I've done several tests with the examples/measure.html (yesterday and
 today) and everything goes correctly (but see NOTE).
 In tests/control/measure.html missing {{{trigger("dblclick", 10, 10);}}}
 but this before "pan while dragging" and did not affect the test because
 the bug r8831 is before this test r9225.
 So, in attachment:3195.2.patch I changed tests/measure.html
 Tested in: IE8, EI6, Chrome-10, Safari. But in FF3.6.15 everything works
 except handler/box.html (fails with or without patch)
 NOTE: Double click sometimes fails in IE8 without {{{<!DOCTYPE >}}} (try
 lines with many points or polygons). For example fails in
 examples/measure.html (see description of this bug in #3194)
 Please review.
Ticket URL: <http://trac.openlayers.org/ticket/3195#comment:5>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
