[OpenLayers-Trac] [OpenLayers] #3219: PanZoomBar tries to zoom outside the valid zoom range
OpenLayers trac-20090302 at openlayers.org
Wed Mar 30 14:03:10 EDT 2011
 Reporter:  saturka             |       Owner:  crschmidt
     Type:  bug                 |      Status:  new
 Priority:  minor               |   Milestone:  2.11 Release
Component:  Control.PanZoomBar  |     Version:  2.10
 Keywords:                      |       State:
 When you tend to drag the bar of the PanZoomBar control too high (north
 off the control) or low (south off the widget), the control tends to do
 zoom into nonsense values. It is because the "zoomBarUp" method of the
 control does not check whether the "zoomLevel" computed value is inside
 the valid range of the current map zooms.
 Play with any map with the PanZoomBar, like
 http://dev.openlayers.org/releases/OpenLayers-2.10/examples/zoomify.html
 http://dev.openlayers.org/releases/OpenLayers-2.10/examples/fractional-
 zoom.html
 Some info at the list:
 http://lists.osgeo.org/pipermail/openlayers-dev/2011-March/007318.html
Ticket URL: <http://trac.openlayers.org/ticket/3219>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
