[OpenLayers-Trac] [OpenLayers] #3221: WMTSCapabilities.createLayer
and Format.WMTS issues
trac-20090302 at openlayers.org
Wed Mar 30 15:55:51 EDT 2011
#3221: WMTSCapabilities.createLayer and Format.WMTS issues
Reporter: woodbri | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.11 Release
Component: general | Version: 2.10
Keywords: | State:
I am trying to get WMTS layer to be created from the WMTSGetCapabilities
document. It seems to be reading the document ok and creating the layer
but the layers does not work correctly.
Here is the getCapabilities document:
http://imaptools.com:8080/geocache/wmts?service=wmts&request=getcapabilities
Here is a simple web page I'm using for testing:
http://imaptools.com:8080/gc4.html
This has 3 layers defined:
1. WMTS in spherical mercator explicitly defining all the parameters.
This layer works fine as far as I can tell. It is for reference and to
show that the service is up and running correctly.
2. This attempts to read the getCapabilites document and create a layer
identical to the above based on the document. It seems that this layer is
in WGS84, degrees, and resolutions, etc if I inspect the map.layer[ 1 ].*
properties, instead of the values from the requested matrixSet.
3. This attempts to read the getCapabilites document and create a layer
that is WGS84 based on the document, and I figured it had at least some
chance of working given the defaults found in 2. And map.zoom==1, shows
two broken tiles with TILEROW=-1
It seems that OpenLayers.Format.WMTSCapabilities() is not creating a
appropriate layer definition from the getCapabilities document.
In OpenLayers.Format.WMTSCapabilities:148 we have:
layer = new OpenLayers.Layer.WMTS(
OpenLayers.Util.applyDefaults(config, {
url:
capabilities.operationsMetadata.GetTile.dcp.http.get,
style: style,
matrixIds: matrixSet.matrixIds
This is not setting:
layer.resolutions[]
layer.projection
layer.units
layer.maxExtents
from the capabilities document information so these are defaulting to
EPSG:4326 values that are not valid for sphericalMercator layers.
Another possible conclusion is that the OpenLayers.Layer.WMTS()
constructor is not populating these items from the matrixIds if all the
information is in there.
Yes, I know that I can set these items manually via the "config" argument,
but this seems to defeat the whole purpose of defining the layer via the
capabilities document in the first place.
And digging into this a little more, it looks like
OpenLayers/Format/OWSCommon/v1.js does not extract the BoundingBox tags at
all:
"BoundingBox": function(node, obj) {
// FIXME: We consider that BoundingBox is the same as
WGS84BoundingBox
// LowerCorner = "min_x min_y"
// UpperCorner = "max_x max_y"
// It should normally depend on the projection
this.readers['ows']['WGS84BoundingBox'].apply(this, [node,
obj]);
According to the standard you can have zero or more of these:
<ows:BoundingBox crs="urn:ogc:def:crs:EPSG::4326">
<ows:LowerCorner>-180.000000 -90.000000</ows:LowerCorner>
<ows:UpperCorner>180.000000 90.000000</ows:UpperCorner>
</ows:BoundingBox>
mod-geocache emits one for each supported crs on a layer and each
TileMatrixSet has a SupportedCRS tag that points back to the appropriate
BoundingBox. So the BoundingBox tags should get extracted as an array
either like:
capabilities.contents.layer[n].bounds{crs} = OpenLayers.Bounds
or
capabilities.contents.layer[n].bounds[0..n] = {
crs: crs,
bounds: OpenLayers.Bounds
Then it would be possible to fix
OpenLayers.Format.WMTSCapabilities.createLayer() to extract the
appropriate information from the capabilities document and create a
working layer.
Ticket URL: <http://trac.openlayers.org/ticket/3221>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
