[OpenLayers-Trac] Re: [OpenLayers] #3016: ModifyFeature - "del" key press outside vertice should delete the feature
OpenLayers trac-20090302 at openlayers.org
Thu May 5 02:15:03 EDT 2011
 Reporter:  adube                  |       Owner:  tschaub
     Type:  feature                |      Status:  new
 Priority:  minor                  |   Milestone:  2.11 Release
Component:  Control.ModifyFeature  |     Version:  2.10
 Keywords:  del, delete, key       |       State:  Review
Comment(by erilem):
 Replying to [comment:10 adube]:
 > I modified and added the required tests and added some new features :
 >  * setState method in OpenLayers.Feature.Vector to actually set the
 state without validating anything and trigger the OpenLayers.Layer.Vector
 "featurestatechanged" event.
 >  * toState method modified to do the validation and call setState
 > I checked the Layer/Vector.js, Feature/Vector.js and
 Control/ModifyFeature.js tests in FF 3.6, 4 and IE8 and everything seemed
 fine.  I got an error in FF 4 but it was not related to the modifications.
 Thanks a lot for the patch. Some review comments below.
 tests/Layer/Vector.html[[BR]]
 tests/Control/ModifyFeature.html
  * we often rely on a {{{log}}} object to test that a function gets
 called, so  message is displayed even if the function is not called. E.g.
 log = false;
 function expected() {
     log = true;
 t.ok(log, "expected function called");
  * I'd rather have a separate test function for "delete key pressed while
 on feature but outside a vertex"
 lib/OpenLayers/Control/ModifyFeature.js
  * we need to document the new behavior in the {{{ModifyFeature}}} API
 docs somewhere
 lib/OpenLayers/Feature/Vector.js
  * if we want to rely on {{{prevState}}} as done in your patch we should
 properly document it
  * but I'd rather have the {{{featurestatechanged}}} event include the
 previous and new states ({{{{feature: this, state: state, previous:
 prevState}}}})
 examples/delete-with-modify-feature.html
  * having a specific example is fine I think, but I'd use a simpler name,
 {{{delete-feature.html}}}
Ticket URL: <http://trac.openlayers.org/ticket/3016#comment:12>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
