[OpenLayers-Trac] Re: [OpenLayers] #3268: EditingToolbar: It shows no control active by default.
OpenLayers trac-20090302 at openlayers.org
Mon May 9 12:52:54 EDT 2011
 Reporter:  jorix                   |       Owner:
     Type:  bug                     |      Status:  new
 Priority:  trivial                 |   Milestone:  2.11 Release
Component:  Control.EditingToolbar  |     Version:  2.10
 Keywords:                          |       State:  Review
Comment(by jorix):
 Replying to [comment:3 erilem]:
 > Thanks for catching this and the patch jorix. It looks good. Would you
 mind adding a test function that checks that the first control is activate
 after the panel is added to the map?
 Yes, I will prepare tests[[BR]]
  (It's almost just an example ;-), and the file
 "tests/Control/EditingToolbar.html" does not exist, so no tests suggested)
Ticket URL: <http://trac.openlayers.org/ticket/3268#comment:4>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
