[OpenLayers-Trac] [OpenLayers] #3304: TRANSPARENT value violates WMS standard
OpenLayers trac-20090302 at openlayers.org
Thu May 19 08:35:00 EDT 2011
 Reporter:  ahocevar   |       Owner:  euzuro
     Type:  bug        |      Status:  new
 Priority:  minor      |   Milestone:  2.12 Release
Component:  Layer.WMS  |     Version:  2.10
 Keywords:             |       State:
 The WMS standard (confirmed for 1.1.1 and 1.3.0) demands that the
 TRANSPARENT param has two valid values, "TRUE" and "FALSE". OpenLayers
 uses "true" and "false".
 From the WMS 1.1.1 spec:
 > 6.4.1 Parameter Ordering and Case
 > Parameter names shall not be case sensitive, but parameter values shall
 be case sensitive. In this document, parameter names are typically shown
 in uppercase for typographical clarity, not as a requirement.
 > 7.2.3.9 TRANSPARENT
 > The optional TRANSPARENT parameter specifies whether the map background
 is to be made transparent or not. TRANSPARENT can take on two values,
 "TRUE" or "FALSE". The default value is FALSE if this parameter is absent
 from the request.
Ticket URL: <http://trac.openlayers.org/ticket/3304>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
