[OpenLayers-Trac] Re: [OpenLayers] #3570: No Such Method
"wkt.replace" Error
trac-20090302 at openlayers.org
Mon Nov 7 13:32:03 EST 2011
#3570: No Such Method "wkt.replace" Error
Reporter: bcrosby | Owner: tschaub
Type: bug | Status: closed
Priority: major | Milestone: 2.12 Release
Component: Format.WKT | Version: 2.11
Resolution: invalid | Keywords:
State: |
Changes (by ahocevar):
* status: new => closed
* resolution: => invalid
Comment:
You are not using the API correctly. if wkt is an instance of
OpenLayers.Format.WKT, then read takes a WKT string as argument, not a
geometry. Maybe you meant to use wkt.write()?
Ticket URL: <http://trac.openlayers.org/ticket/3570#comment:1>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
