[OpenLayers-Trac] Re: [OpenLayers] #3567: Map: Bug due to #3531
trac-20090302 at openlayers.org
Mon Nov 7 13:34:34 EST 2011
Reporter: jorix | Owner:
Type: bug | Status: new
Priority: major | Milestone: 2.12 Release
Component: Map | Version: 2.11
Keywords: | State:
Comment(by jorix):
Replying to [comment:2 ahocevar]:
> @jorix: Can you be a bit more specific? What is the faulty behavior on
the sundials-spherical-mercator example? What would be the expected
behavior? Can you provide a test case that shows the issue?
Auto width in Popups does not work, it is always 100px.
See at
http://www.openlayers.org/dev/examples/popupMatrix.html
and compare with:
http://dev.openlayers.org/releases/OpenLayers-2.11/examples/popupMatrix.html
This is one of the manifestations of the problem:
* Function {{{OpenLayers.Util.getRenderedDimensions}}} does not work
properly if {{{options.containerElemen = map.layerContainerDiv}}} in
{{{options}}} argument.
The cause is here
[https://github.com/openlayers/openlayers/commit/ded64c00d42317ad0bac32a5e62f8597068c0bc2#diff-8
commit GitHub Map.js line 539] before this change it works.
Ticket URL: <http://trac.openlayers.org/ticket/3567#comment:3>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
