[OpenLayers-Trac] [OpenLayers] #3537: feature clickout might not be triggered
OpenLayers trac-20090302 at openlayers.org
Tue Oct 4 13:00:43 EDT 2011
 Reporter:  anrikun  |       Owner:
     Type:  bug      |      Status:  new
 Priority:  major    |   Milestone:  2.12 Release
Component:  general  |     Version:  2.11
 Keywords:           |       State:
 I had a problem with my Control.SelectFeature: sometimes onUnselect was
 not called.
 After debugging for hours, I think I've finally found the bug and a fix.
 The problem is that in Handler/Feature.js, line 281, there is:
         if(this.lastFeature && !this.lastFeature.layer) {
             // last feature has been destroyed
             this.lastFeature = null;
 But in Control/SelectFeature.js, line 510, there is:
                 if(!this.handlers.feature.lastFeature) {
                     this.handlers.feature.lastFeature =
 layer.selectedFeatures[0];
 This means, that is the selected feature has been destroyed, Feature.js
 clears lastFeature, but SelectFeature.js does not perform the same check!
 To fix that, Control/SelectFeature.js, line 510 should be:
                 if(!this.handlers.feature.lastFeature ||
 !this.handlers.feature.lastFeature.layer) {
Ticket URL: <http://trac.openlayers.org/ticket/3537>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
