[OpenLayers-Trac] Re: [OpenLayers] #3554: single-arg Map constructor does not work if you pass a DOM element ref
OpenLayers trac-20090302 at openlayers.org
Thu Oct 20 03:57:12 EDT 2011
 Reporter:  domurtag  |       Owner:
     Type:  bug       |      Status:  new
 Priority:  major     |   Milestone:
Component:  Map       |     Version:  2.11
 Keywords:            |       State:
Comment(by ahocevar):
 We also accept patches; whatever works better for you. Speaking of: I
 attached an untested patch that should do the trick. Contribution of unit
 tests is still welcome - otherwise this probably won't make it into the
 library.
Ticket URL: <http://trac.openlayers.org/ticket/3554#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
