[OpenLayers-Trac] Re: [OpenLayers] #3531: add continuous zooming support for tiled layers
OpenLayers trac-20090302 at openlayers.org
Fri Oct 21 03:32:17 EDT 2011
  Reporter:  erilem      |       Owner:  elemoine
      Type:  feature     |      Status:  closed
  Priority:  major       |   Milestone:  2.12 Release
 Component:  Layer.Grid  |     Version:  2.11
Resolution:  fixed       |    Keywords:
     State:  Commit      |
Comment(by erilem):
 Replying to [comment:6 scaddenp]:
 > Suppose server doesnt support low resolutions? ie. serverResolutions
 start at zoom 3.
 > At moment, this throws an exception in getServerResolution.
 Thanks for asking this question.
 {{{getServerResolution}}} indeed returns the closest highest server
 resolution, and throws an exception if none is found.
 This means that cases such as {{{resolutions:[8, 4, 2]
 serverResolutions:[4, 2]}}} are not currently supported.
 Instead of working with the closest highest server resolution we could
 possibly work with the server closest resolution, which can be lower that
 the map resolution. This would cover the aforementioned use-case, and
 possibly allows using a better server resolution.
 I'm interested about your opinion about this.
Ticket URL: <http://trac.openlayers.org/ticket/3531#comment:7>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
