[OpenLayers-Trac] [OpenLayers] #3517: WPSExecute ComplexData input fix (patch included)
OpenLayers trac-20090302 at openlayers.org
Fri Sep 23 21:00:20 EDT 2011
 Reporter:  jachym             |       Owner:  bartvde
     Type:  feature            |      Status:  new
 Priority:  minor              |   Milestone:  2.12 Release
Component:  Format.WPSExecute  |     Version:  2.11
 Keywords:                     |       State:
 If the input options structure for
 OpenLayers.Format.WPSExecute.prototype.write() method contains
        complexData: {
                   attributes: {
                      mimeType: "text/xml"
                    value: <XML_ELEMENT>
 so, some XML element (e.g. created with  OpenLayers.Format.XML),
 than the XML nodes are handled as text, and WPS server  implementations do
 not like them.
 The patch takes care, whether the input data is string or not. If not, it
 is assumed, that the input data are already DOMEelement, and they can be
 appended to parent element as child node. If they are string, the original
 approach is used.
Ticket URL: <http://trac.openlayers.org/ticket/3517>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
