[OpenLayers-Trac] [OpenLayers] #3647: "mapProjection is null" error in merge method when vector layers using the fixed strategy are loaded prior to the base layer
OpenLayers trac-20090302 at openlayers.org
Fri Apr 13 15:53:06 EDT 2012
 Reporter:  parkerb2        |       Owner:  tschaub
     Type:  bug             |      Status:  new
 Priority:  minor           |   Milestone:
Component:  Strategy.Fixed  |     Version:  2.11
 Keywords:                  |       State:
 The resolution in ticket 2851 caused the projection object of the
 baselayer to essentially be saved off at the time the layer is loaded into
 the map. So if a vector layer using the fixed strategy is loaded prior to
 the map's base layer, all calls to the merge method pass null as the
 mapProjection parameter and fail.
Ticket URL: <http://trac.openlayers.org/ticket/3647>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
