[OpenLayers-Trac] [OpenLayers] #3649: Vector layers sometimes
offset after map resize and map drag
trac-20090302 at openlayers.org
Sat Apr 21 05:57:41 EDT 2012
#3649: Vector layers sometimes offset after map resize and map drag
Reporter: apexer | Owner:
Type: bug | Status: new
Priority: major | Milestone:
Component: general | Version: 2.11
Keywords: | State:
Steps to reproduce.
1. Place the map in a container which can be resized, such as a jquery-ui-
layout panel.
2. Put a vector layer on the map.
3. Resize map
4. Click and drag map to move it. Notice the map jump as you start
dragging (100% reproducible).
5. Sometimes the vector layer is still stuck in the position where the map
"jumped" from. Leaving an offset which is stuck after zooming and panning.
6. Rezible the map a couple of times and the offset will fix itself.
Tested with Google Chrome 18
Ticket URL: <http://trac.openlayers.org/ticket/3649>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
