[OpenLayers-Trac] [OpenLayers] #3651: rotating labels with SVG
trac-20090302 at openlayers.org
Thu Apr 26 14:32:16 EDT 2012
Reporter: bennos | Owner:
Type: feature | Status: new
Priority: minor | Milestone:
Component: Renderer | Version: 2.11
Keywords: labels, renderer, rotate, SVG, VML | State:
for a map i needed rotated labels and after some research i found
thachun's post on the mailing list [http://osgeo-org.1560.n6.nabble.com
/How-to-rotate-a-label-in-IE-td3923751.html]. He uses a modified version
of the SVG-Renderer and the VML-Renderer in OL 2.8. I couldn't use the
VML-Renderer, because it is for line features, but I modified the OL 2.11
SVG-Renderer to rotate labels (point or line, no difference). This works
in all Browsers except Internet explorer below 9. You can see a working
example at [http://www.gorjanci.at/zemljevid/karta.html]
Maybe there is someone interested in developing it further, especially for
VML to obtain browser compatibility.
The Changes in the SVG.js would be:
* Method: drawText
* This method is only called by the renderer itself.
* Parameters:
* featureId - {String}
* style -
* location - {<OpenLayers.Geometry.Point>}
drawText: function(featureId, style, location) {
var resolution = this.getResolution();
//add this for rotation----------------------------------------
var layer = this.map.getLayer(this.container.id);
var feature = layer.getFeatureById(featureId);
location = (feature.attributes.centroid ? feature.attributes.centroid :
location);
var x = (location.x / resolution + this.left);
var y = (location.y / resolution - this.top);
var label = this.nodeFactory(featureId + this.LABEL_ID_SUFFIX, "text");
label.setAttributeNS(null, "x", x);
label.setAttributeNS(null, "y", -y);
if (style.angle || style.angle == 0) {
var rotate = 'rotate(' + style.angle + ',' + x + "," + -y + ')';
label.setAttributeNS(null, "transform", rotate);
if (style.fontColor) {
label.setAttributeNS(null, "fill", style.fontColor);
if (style.fontOpacity) {
label.setAttributeNS(null, "opacity", style.fontOpacity);
if (style.fontFamily) {
label.setAttributeNS(null, "font-family", style.fontFamily);
StyleMap with angle-Attribute:
var styleMap = new OpenLayers.StyleMap({
label : "${label}",
cursor: "pointer",
labelXOffset: 0,
labelYOffset: 0,
fontColor: "black",
fontSize: "24px",
fontFamily: "Arial",
labelSelect: true,
labelAlign: "cm",
angle: "${angle}"
And the Layer with the new renderer:
var vectorLayer = new OpenLayers.Layer.Vector("newLayer", {
styleMap: myStylemap,
strategies: [myStrategy],
renderers: ["CustomSVG", "VML"], //VML only for IE <= 8, labels are not
rotated
protocol: new OpenLayers.Protocol.HTTP({
url: "gml/myGML.gml", // or some other source
format: new OpenLayers.Format.GML()
I created a patch for OL 2.11, additionally I am attaching thachun's
original files.
Cheers,
Benjamin
Ticket URL: <http://trac.openlayers.org/ticket/3651>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
