[OpenLayers-Trac] Re: [OpenLayers] #3615: Google v3 layer option: disableTilt
OpenLayers trac-20090302 at openlayers.org
Thu Feb 9 13:26:51 EST 2012
 Reporter:  guest                               |       Owner:
     Type:  feature                             |      Status:  new
 Priority:  minor                               |   Milestone:  2.12 Release
Component:  Layer.Google.v3                     |     Version:  2.11
 Keywords:  google, tilt, alignment, 45 degree  |       State:  Needs More Work
Comment(by guest):
 I sent out the CLA a little bit ago via email. "Allensworth"
 I agree entirely about tilt being turned off by default, though I was
 skittish about changing a default behavior.
 Attached is an updated patch:
 * APIProperty: enableTilt
 * {Boolean} If set to true, Google's 45-degree tilt view will be enabled.
 *     Default is false, which disables 45-degree tilt.
 *     Note that enabling 45-degree tilt may cause problems with overlays
 and markers matching up to the map.
Ticket URL: <http://trac.openlayers.org/ticket/3615#comment:2>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
