[OpenLayers-Trac] [OpenLayers] #3618: Problems with closure compiler under windows.
OpenLayers trac-20090302 at openlayers.org
Mon Feb 13 15:17:08 EST 2012
 Reporter:  scaddenp  |       Owner:
     Type:  feature   |      Status:  new
 Priority:  minor     |   Milestone:  2.12 Release
Component:  general   |     Version:  2.11
 Keywords:            |       State:
 The README instructions for closure compiler do not work. Looking at the
 build.py,
 looking in build.py, I found comments which refer to a jscompiler.py which
 presumably gets renamed to closure_library_jscompiler. I downloaded that.
 Now get.
 C:\Program Files\openlayers\build>build.py -c closure full
 OpenLayers-closure.js
 Merging libraries.
    File "C:\Program Files\openlayers\build\build.py", line 117, in
 <module>
      build(args[0], args[1], options=options)
    File "C:\Program Files\openlayers\build\build.py", line 55, in build
      sourceFiles = mergejs.getNames(sourceDirectory, configFilename)
 AttributeError: 'module' object has no attribute 'getNames'
 Summit broken here...
 I tried this a checkout of the current svn openlayers.
 Workaround:
    build.py -c none myconfig.cfg uncompressed.js
    java -jar ..\tools\closure-compiler.jar --js uncompressed.js
 --js_output_file OpenLayers-closure.js
     copy /b license.txt+OpenLayers-closure.js ..\OpenLayers.js
Ticket URL: <http://trac.openlayers.org/ticket/3618>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
