[OpenLayers-Trac] [OpenLayers] #3621: calculateResolutions - fault
with min/max scale denomiators when both set to 0.
trac-20090302 at openlayers.org
Thu Feb 16 06:31:48 EST 2012
#3621: calculateResolutions - fault with min/max scale denomiators when both set
to 0.
Reporter: coastal | Owner: euzuro
Type: bug | Status: new
Priority: minor | Milestone: 2.12 Release
Component: Layer.WMS | Version: 2.11
Keywords: calculateResolutions minscaledenominator maxscaledenominator | State:
When connecting to a WMS that has an incorrect getCapbilities response the
calculateResolutions function fails with 'invalid array length'.
http://mapgateway.snh.gov.uk/ServicesWMS/FCS_Admin_Boundaries/MapServer/WMSServer?
is the server that we've tested against. The getCapabilities response
returns 0.0000000 values for min & max scale denominators. In the below
calculate resolutions check numZoomLevels is NaN so goes through fine but
fails at the array creation. I suspect a isNaN check should be included in
the check as well.
// are we able to calculate resolutions?
if(typeof numZoomLevels !== "number" || numZoomLevels <= 0 || (typeof
maxResolution !== "number" && typeof minResolution !== "number")) {
return;
// now we have numZoomLevels and at least one of maxResolution
// or minResolution, we can populate the resolutions array
var resolutions = new Array(numZoomLevels);
Ticket URL: <http://trac.openlayers.org/ticket/3621>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac
