[OpenLayers-Trac] Re: [OpenLayers] #2964: Error in Layer.Zoomify when width or height is evenly divisible by 256
OpenLayers trac-20090302 at openlayers.org
Mon Feb 20 14:05:38 EST 2012
 Reporter:  alpage   |       Owner:  euzuro
     Type:  bug      |      Status:  new
 Priority:  major    |   Milestone:  2.12 Release
Component:  Layer    |     Version:  2.11
 Keywords:  zoomify  |       State:  Review
Comment(by rboulton):
 This pull request seems incorrect for an input height of 0; it will
 produce a value of this.standardTileSize, whereas if the tile is actually
 of 0 height it seems better to return a height of 0.  Similarly for the
 width.
 I'm not sure if this is significant, but I remember being concerned about
 it 10 months ago when I put my patch together.  I think I saw some issue
 when the tiles failed to get rendered by the server which was less
 disasterous with a return value of 0 here.
 If you want an explicit test for readability, I'd suggest doing an
 explicit if; I don't find your version more readable than mine, really.
 Or, you could do:
                 h = (this.tierImageSize[z].h % this.standardTileSize) ||
 (this.tierImageSize[z].h && this.standardTileSize)
 if you want a one liner.  Worse than my version I think, though.
Ticket URL: <http://trac.openlayers.org/ticket/2964#comment:6>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
