[OpenLayers-Trac] Re: [OpenLayers] #3194: Problem with double click to finish a drawing using IE6
OpenLayers trac-20090302 at openlayers.org
Mon Feb 27 06:32:28 EST 2012
 Reporter:  jorix         |       Owner:  tschaub
     Type:  bug           |      Status:  new
 Priority:  major         |   Milestone:  2.12 Release
Component:  Handler.Path  |     Version:  SVN
 Keywords:                |       State:  Needs More Work
Comment(by jorix):
 Replying to [comment:10 leole]:
 > Thanks. That patch works perfectly within my application using IE8 and
 fixes the problem with the double click there. It works also correctly in
 my FFOX 10.0. If you need testing, just contact me
 I like the approach of this patch as it cleans controls with problems in
 the double-click as Measure.
 But I do not know if !OpenLayers team shares my point of view, I'm afraid
 not. Is for this reason I have not worked in the tests for now.
Ticket URL: <http://trac.openlayers.org/ticket/3194#comment:11>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
