[OpenLayers-Trac] [OpenLayers] #3658: OpenLayers.Control.TransformFeature extend and impove
OpenLayers trac-20090302 at openlayers.org
Thu May 17 07:58:59 EDT 2012
 Reporter:  paweluz                   |       Owner:  ahocevar
     Type:  feature                   |      Status:  new
 Priority:  minor                     |   Milestone:
Component:  Control.TransformFeature  |     Version:  2.11
 Keywords:                            |       State:
 - It would be really helpful if this control had ability to add rotation
 point not only in the corner of the feature, but in the middle of
 side(edge) as well.
 - Method createBox() could be divided into smaller functions. For
 providing rotation point in "n" position in my new class I had to copy
 this hole function with just 2,3 lines changed.
 - I think it would be perfect if when user select the edge and resize the
 feature the feature would resize just from this side. Not as well with the
 opposite side. Like it is done in MSPaint when you draw a rectangle and
 you grab one side and resize. maybe some configuration option would be a
 great solution for that. To resize just from the place you select.
Ticket URL: <http://trac.openlayers.org/ticket/3658>
OpenLayers <http://openlayers.org/>
A free AJAX map viewer
More information about the Trac mailing list
