[OpenLayers-Users] TileCache and KaMaps
Tim Schaub noreply at geocartic.com
Wed Dec 6 13:18:12 EST 2006
> After spending last night hacking with Schuyler, I'm now
> convinced that TileCache supports transparency correctly, and
> that metaTiling is now of a quality where I trust it. It
> doesn't do mapscript hacks to prevent labelling in the
> metaBuffer area, but presuming a relatively small metabuffer
> (and PARTIALS OFF, which doesn't cooperate well with ka-Map)
> the difference between ka-Map and TileCache behavior is
> probably minimal, and the benefits of switching are, in my
> humble opinion, significant.
Note that you don't need to rely on mapscript to prevent labels in a buffer
around the edge of your map.  If you're using MapServer to generate your
tiles, there's a mapfile metadata hack for that (since 4.6):
WEB
  METADATA
    "labelcache_map_edge_buffer" "10" #pixels
  END
END
also, don't forget
  PARTIALS FALSE
Keep an eye on mapserver bug #1353 if you're hesitant to use "experimental"
features (http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1353).
Tim
> I look forward to hearing any questions or concerns you have
> about making a switch.
> Regards,
> Christopher Schmidt
> MetaCarta
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
