[OpenLayers-Users] Initial question: Cannot display controls
Xiaopeng Xiong xpxiong at purdue.edu
Mon Dec 11 14:29:46 EST 2006
Thanks Marco, it is working now. I appreciate the help.
I did download the .js file, but was not aware that I need the img directory
as well.
Best,
Xiaopeng
----- Original Message -----
From: "Marco Zühlke" <Marco.Zuehlke at brockmann-consult.de>
To: <users at openlayers.org>
Sent: Monday, December 11, 2006 2:04 PM
Subject: Re: [OpenLayers-Users] Initial question: Cannot display controls
> Xiaopeng Xiong wrote:
>> Hello List,
>> I just tried the live demo at
>> http://openlayers.org/dev/examples/click.html. It works fine.
>> So I copied the exact source code into my own html file. But none control
>> is displayed well. You can check my html at
>> http://www.cs.purdue.edu/homes/xxiong/OpenLayers/clicks.html
>> Did I miss anything here?
> Hello,
> you copied over only the Javascript file from the Openlayers server. The
> destination of the images relates to location of the Javascript file. You
> have two possibilities:
> -  You can directly reference the Javascript on the Openlayer server, by
> pointing to http://openlayers.org/api/2.2/OpenLayers.js
> - Download the distribution and install parallel to the 'lib' directory
> also
> the 'theme' and the 'img' directory.
> This should fix your problem.
>> My another question is that what are the event names for mouse pressing,
>> dragging and releasing?
> Have a look at:
> http://trac.openlayers.org/browser/trunk/openlayers/lib/OpenLayers/Events.js#L123
> Regards,
> Marco
>> I appreciate any help and suggestions.
>> Thanks,
>> Xiaopeng
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
