[OpenLayers-Users] PostgreSQL dynamic layer
Moser Adrian
Adrian.Moser at bs.ch
Thu Nov 2 07:33:32 EST 2006
Hi list,
I already posted this question once but couldn't solve the problem.
I'm implementing a routing application based on PostgreSQL/PostGIS. The routes are stored temporarily in a Postgres table together with the current session-ID. I then included this table in a Mapserver Layer which I want to show with OpenLayers. The problem is that could be different routes in the table and I just want to display the one belonging to the current session.
There is a parameter expression that can be set in the .map file but I need to do this dynamically.
Mapserver Layer:
LAYER
NAME path
CONNECTIONTYPE POSTGIS
CONNECTION "user=xxx password=xxx dbname=xxx host=localhost port=5432"
DATA "the_geom from routingrouten"
PROJECTION
"init=epsg:4326"
END
STATUS ON
TYPE LINE
CLASS
NAME 'path'
STYLE
COLOR 0 255 0
WIDTH 3
END
END
METADATA
"wms_title" "path"
END
END
JavaScript function:
function showRoute(sessId) {
//Berechente Route anzeigen
wms_path = new OpenLayers.Layer.WMS("path",
'http://localhost/cgi-bin/mapserv.exe?map=c:/ms4w/Apache/htdocs/nafmomNeu/map/nafmom.map',
{LAYERS: 'path', format: 'png', transparent: 'true'},{'buffer':1});
map.addLayer(wms_path);
Is there a possibility to do this?
I noticed that if I display a route (currently all routes are displayed) and the recalculate the route with slightly other start and end point an display it OpenLayers still shows the old route. It display to show a cached tile. How can I solve this problem?
