[OpenLayers-Users] OpenLayers 2.2 breaks with jQuery
Daniel Kastl daniel.kastl at gmx.de
Tue Nov 21 23:17:21 EST 2006
Hi Brent,
Sorry, but I missunderstood your answer.
I also tried your way and changed the order of OpenLayers and jQuery
without renaming the $ to JQ, but it didn't help either. Usually the
renaming of $ should be the more save way, I think.
Daniel
Daniel Kastl wrote:
> Hi Brent,
> That's what I did, see:
>   <script type="text/javascript"
> src="http://jquery.com/src/jquery-latest.pack.js
> <http://jquery.com/src/jquery-latest.pack.js>"></script>
>   <script type="text/javascript">
>     JQ = $;  // rename $ function to use jQuery together with Prototype
>   </script>
>   <script type="text/javascript" src="./2.2/lib/OpenLayers.js"></script>
> It was working as expected with 2.1, but with 2.2 it doesn't work
> anymore. I didn't call any jQuery function, just included the lines
> above and it gives an error. In the 2.2 release mail, there was written:
>     * Refactoring the use of Prototype.js. Rather than using
> Prototype.js, OpenLayers has integrated the important pieces of the
> Prototype framework into OpenLayers, and removed offending functions
> like Object.extend(). This means that there should no longer be
> conflicts between OpenLayers and different versions of Prototype, or
> any other Javascript framework.
> I guess, it's because of changes to the original Protoype library.
> Daniel
> Brent Pedersen wrote:
>> hi, i havent tried this, but i think you shouldnt have to alias jquery
>> as JQ, just use jQuery (where you'd normally use $), and include it
>> _after_ any prototype/OL stuff.
>> the jquery srcipt checks if $ exists, if so, it doesnt create that
>> namespace.
>> -brent
>> On 11/21/06, *Daniel Kastl* <daniel.kastl at gmx.de
>> <mailto:daniel.kastl at gmx.de>> wrote:
>>     Hi list,
>>     While with version 2.1 of OpenLayers there was no problem to use both
>>     OpenLayers' Prototype and jQuery javascript framework, it doesn't work
>>     anymore with version 2.2.
>>     Firebug error message:
>>     "this.div.appendChild is not a function" in Map.js (line 136):
>>     this.div.appendChild(this.viewPortDiv);
>>     I followed the jQuery guide how to run jQuery together with Prototype
>>     library ( http://jquery.com/docs/PrototypeAndJQuery/)
>>     I tested with the Wiki example:
>>     <?xml version="1.0" encoding="UTF-8" ?>
>>     <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
>>     "xhtml1-transitional.dtd">
>>     <html xmlns="http://www.w3.org/1999/xhtml" xml:lang="jp" lang="jp">
>>     <head>
>>       <meta http-equiv="Content-type"  content="text/html; />
>>       <title>OpenLayers Demo</title>
>>       <!-- jQuery -->
>>     Prototype
>>       </script>
>>       <!-- OpenLayers -->
>>     </head>
>>     <body>
>>       <div id="map" style="width:100%;height:100%;"></div>
>>       <script defer="defer" type="text/javascript">
>>         var map = new OpenLayers.Map('map');
>>         var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>             "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
>>         map.addLayer(wms);
>>         map.zoomToMaxExtent();
>>       </script>
>>     </body>
>>     Would be nice somebody knows a solution how to use both,
>>     OpenLayers and
>>     jQuery.
>>     Daniel
>>     _______________________________________________
>>     Users mailing list
>>     Users at openlayers.org <mailto:Users at openlayers.org>
>>     http://openlayers.org/mailman/listinfo/users
> Users mailing list
