[OpenLayers-Users] OpenLayers 2.2 breaks with jQuery
Daniel Kastl daniel.kastl at gmx.de
Wed Nov 22 00:17:29 EST 2006
Thank you, Tim!
Now it's working again.
Daniel
Tim Schaub wrote:
> I think this is what is happening:
> 1) You load up jQuery, this defines the $ function
> 2) You define JQ to be the same thing as $
> 3) You load OpenLayers, this checks if $ exists, and because it does exist,
> it is not redefined in the OL (prototype) way
> 4) You initialize your map and send it the string 'map' as the first
> argument
> 5) OpenLayers tries to place your map in the DOM element $('div'), but
> because $() is still a jQuery function that doesn't return a DOM element,
> you get the error about appendChild not being defined
> So (without knowing anything about jQuery), I think your problem would be
> solved if you did this in your second script tag:
> JQ = $;
> $ = null;
> This would let OpenLayers define $ in the way that it wants to (which it
> only does if $ == null), which would take your 'map' string and return a DOM
> element instead of whatever jQuery returns with $('map').
> Regardless of whether this works or not, it does bring up an OpenLayers
> issue.  The docs say that the map constructor takes a DOM element as the
> first argument.  In practice (and the way the function works), this is
> usually a string id for a DOM element instead.
> Tim
> (Alternatively, it seems like you should be able to load jQuery after
> OpenLayers - but it sounds like that didn't do the trick.)
>> -----Original Message-----
>> From: users-bounces at openlayers.org
>> [mailto:users-bounces at openlayers.org] On Behalf Of Daniel Kastl
>> Sent: Tuesday, November 21, 2006 9:17 PM
>> To: Daniel Kastl
>> Cc: users at openlayers.org
>> Subject: Re: [OpenLayers-Users] OpenLayers 2.2 breaks with jQuery
>> Hi Brent,
>> Sorry, but I missunderstood your answer.
>> I also tried your way and changed the order of OpenLayers and
>> jQuery without renaming the $ to JQ, but it didn't help
>> either. Usually the renaming of $ should be the more save
>> way, I think.
>> Daniel
>> Daniel Kastl wrote:
>>> Hi Brent,
>>> That's what I did, see:
>>>   <script type="text/javascript"
>>> src="http://jquery.com/src/jquery-latest.pack.js
>>> <http://jquery.com/src/jquery-latest.pack.js>"></script>
>>>   <script type="text/javascript">
>>>     JQ = $;  // rename $ function to use jQuery together
>> with Prototype
>>>   </script>
>>> src="./2.2/lib/OpenLayers.js"></script>
>>> It was working as expected with 2.1, but with 2.2 it doesn't work
>>> anymore. I didn't call any jQuery function, just included the lines
>>> above and it gives an error. In the 2.2 release mail, there
>> was written:
>>>     * Refactoring the use of Prototype.js. Rather than using
>>> Prototype.js, OpenLayers has integrated the important pieces of the
>>> Prototype framework into OpenLayers, and removed offending
>> functions
>>> like Object.extend(). This means that there should no longer be
>>> conflicts between OpenLayers and different versions of
>> Prototype, or
>>> any other Javascript framework.
>>> I guess, it's because of changes to the original Protoype library.
>>> Daniel
>>> Brent Pedersen wrote:
>>>> hi, i havent tried this, but i think you shouldnt have to alias
>>>> jquery as JQ, just use jQuery (where you'd normally use $), and
>>>> include it _after_ any prototype/OL stuff.
>>>> the jquery srcipt checks if $ exists, if so, it doesnt create that
>>>> namespace.
>>>> -brent
>>>> On 11/21/06, *Daniel Kastl* <daniel.kastl at gmx.de
>>>> <mailto:daniel.kastl at gmx.de>> wrote:
>>>>     Hi list,
>>>>     While with version 2.1 of OpenLayers there was no
>> problem to use both
>>>>     OpenLayers' Prototype and jQuery javascript framework,
>> it doesn't work
>>>>     anymore with version 2.2.
>>>>     Firebug error message:
>>>>     "this.div.appendChild is not a function" in Map.js (line 136):
>>>>     this.div.appendChild(this.viewPortDiv);
>>>>     I followed the jQuery guide how to run jQuery together
>> with Prototype
>>>>     library ( http://jquery.com/docs/PrototypeAndJQuery/)
>>>>     I tested with the Wiki example:
>>>>     <?xml version="1.0" encoding="UTF-8" ?>
>>>>     <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
>>>>     "xhtml1-transitional.dtd">
>>>>     <html xmlns="http://www.w3.org/1999/xhtml"
>> xml:lang="jp" lang="jp">
>>>>     <head>
>>>>       <meta http-equiv="Content-type"  content="text/html; />
>>>>       <title>OpenLayers Demo</title>
>>>>       <!-- jQuery -->
>>>>         JQ = $;  // rename $ function to use jQuery together with
>>>>     Prototype
>>>>       </script>
>>>>       <!-- OpenLayers -->
>>>>     </head>
>>>>     <body>
>>>>       <div id="map" style="width:100%;height:100%;"></div>
>>>>       <script defer="defer" type="text/javascript">
>>>>         var map = new OpenLayers.Map('map');
>>>>         var wms = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>>>>             "http://labs.metacarta.com/wms/vmap0",
>> {layers: 'basic'} );
>>>>         map.addLayer(wms);
>>>>         map.zoomToMaxExtent();
>>>>       </script>
>>>>     </body>
>>>>     Would be nice somebody knows a solution how to use both,
>>>>     OpenLayers and
>>>>     jQuery.
>>>>     Daniel
>>>>     _______________________________________________
>>>>     Users mailing list
>>>>     Users at openlayers.org <mailto:Users at openlayers.org>
>>>>     http://openlayers.org/mailman/listinfo/users
>>> Users mailing list
>> Users mailing list
> Users mailing list
