[OpenLayers-Users] Problems setting up TileCache
Ben Brehmer bbrehmer at refractions.net
Wed Nov 22 11:56:29 EST 2006
Christopher Schmidt wrote:
> On Tue, Nov 21, 2006 at 03:10:17PM -0800, Ben Brehmer wrote:
>> Hello Everyone,
>> I have setup a very basic Open Layers application and am now in the
>> process of setting up TileCache. I have proded and poked my
>> tilecache.cfg file extensively and still can't get past an error which
>> has to do with with the "type" attribute for the [cache] section.
>> Basically when tilecache.cgi is invoked it never gets past parsing the
>> .cfg file and errors out at the "type=DiskCache" line, saying that the
>> string requires a character as left operand.
>> Is there some other configuration issues I should know about when
>> setting up TileCache?
>> Error and cfg file details:
>> tilecache.cfg file:
>> [cache]
>> type=DiskCache                                        <-----------Error
>> base=/home/httpd/cf2/html/tilecache/
>> [basic]
>> type=WMSLayer
>> url=http://office.refractions.net/ms/cgi-bin/mapserv
>> extension=png
>> The error I pull out of my error log:
>> TypeError:
>> 'in <string>' requires character as left operand
> Oddly enough, this sounds like a bug in ConfigParser more than anything
> else... Do the logs give you any kind of traceback or anything like a
> line number where the error is happening?
> We're using Python2.4 for our TileCache workings, but I know that people
> have got it running under 2.3 -- this error is definitely something you
> wouldn't see under Python2.4, but I don't know if that would fix your
> problem.
> I've just downloaded a clean TileCache 1.1, and edited tilecache.cgi to
> use Python2.3, and I'm not getting this error, unfortunately. If you
> could give any more information as to where in the code this error is
> happening, I'd appreciate it, and will investigate as best I can.
> Regards,
Hi Christopher,
This is the complete error log:
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] Traceback (most
recent call last):
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]   File
"/home/httpd/cf2/cgi-bin/tilecache-1.1/tilecache.cgi", line 6, in ?
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     svc =
Service.load(*cfgfiles)
"/home/httpd/cf2/cgi-bin/tilecache-1.1/TileCache/Service.py", line 249,
in _load
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     cache =
cls.loadFromSection(config, "cache", Cache)
"/home/httpd/cf2/cgi-bin/tilecache-1.1/TileCache/Service.py", line 232,
in _loadFromSection
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1]     if opt not
in ("type"):
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] TypeError: 'in
[Wed Nov 22 08:48:23 2006] [error] [client 192.168.50.1] Premature end
of script headers: tilecache.cgi
I definitely agree with you that this is a problem in ConfigParser,
although this may be related to me using Python 2.2.3. I am going to
install Python 2.4 this morning. I"ll let you know if that was the cause
of my problems.
Thanks for you help,
Ben
