[OpenLayers-Users] wfs-t not working in IE ?
Louvy Joseph louvy.joseph at gmail.com
Sun Apr 1 13:22:34 EDT 2007
I am hitting the problems even before control comes to XMLSerializer. I
am seeing issues in createElementNS(). I started replacing all the
createElementNS() calls with createElement()  but then I started hitting
at appendChild(). Is there a generic way around createElementNS() &
appendChild() calls?
BTW, how do you guys debug the Javascript in IE? (Firebug was so breeze
and gosh, IE debugging is so painful).
Thanks
Louvy
Christopher Schmidt wrote:
> On Sat, Mar 31, 2007 at 10:17:32PM -0700, Louvy Joseph wrote:
>> Hi folks,
>> I can get the wfs-t.html example work fine in firefox against my
>> geoserver but it fails in IE.  The status bar at the bottom on IE 7 says
>> "Error on page". When I click it, it shows error on vague line number
>> saying "Object does not support this property or method". Line number
>> does not seem to match where the actual error is found.
>> Is there a known issue with IE & wfs-t insert transaction? How do I
>> debug javascript in IE?
> "# Internet Explorer does not have a built in XML Serializer, so it can
> not save WFS-T payloads to a server via the 'commit' method on a WFS
> layer."
>   --  http://trac.openlayers.org/wiki/Release/2.4/Notes
> "IE has no built in XML Serializer. The
> OpenLayers.Ajax.serializeXMLToString function will fail in IE. We should
> choose a library which has an XML Serializer with namespace support in
> it and allow users to use it with IE to add serialize support."
>  -- http://trac.openlayers.org/ticket/535
> I spent several hours looking for an XML Serializer for IE, and couldn't
> find one. It's possible I missed something. If you have one loaded, the
> function to modify is OpenLayers.Ajax.serializeXMLToString -- it should
> accept an XML DOM object, and return a string. If you can make this
> happen on IE, there are no other known problems with the WFS-T in
> Internet Explorer.
> Regards,
