[OpenLayers-Users] A very simple application doesn't work
Dmitri Mizerkin
eisberg at gmail.com
Wed Apr 4 11:22:42 EDT 2007
It has worked! Thank you!
BR,
Dmitri
On 4/4/07, Dmitri Mizerkin <eisberg at gmail.com> wrote:
> Hi Christopher,
> just received your previous mail and find the topic you mentioned. Thanks
> for a rapid feedback.
> BR,
> Dmitri
> On 4/4/07, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> > On Wed, Apr 04, 2007 at 05:12:44PM +0200, Dmitri Mizerkin wrote:
> > > Hi Steve,
> > > I assume it is working with the Layer/Mapserver class, only that the
> > site is
> > > still empty. I looked at the address of the map in the the properties
> > window
> > > - the part of it that as I suspect prevents it from working is the
> > > mapextent, which is set to -180 -90 180 270 (initial maximum extent).
> > > Setting up the extent via OpenLayers didn't bring any success neither
> > over
> > > var wms2 = new OpenLayers.Layer.MapServer("BGL Abschnitte", "
> > > http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/test/htdocs/test.map
> > > {mode: 'map', layers: 'Flaeche', mapext: '2574985.815002
> > 5646323.449916
> > > 2587295.900005 5655021.169988'});
> > Don't do this.
> > Read this:
> > http://trac.openlayers.org/wiki/FrequentlyAskedQuestions#Projections
> > then do this:
> > new OpenLayers.Map("map", {maxExtent: new
> > OpenLayers.Bounds(2574985.815002, 5646323.449916, 2587295.900005,
> > 5655021.169988),
> > maxResolution: 'auto', units: 'meters', projection: "EPSG:41001"});
> > combined with something like:
> > > var bounds = new OpenLayers.Bounds(2574985.815002, 5646323.449916 ,
> > > 2587295.900005, 5655021.169988);
> > > map.zoomToExtent(bounds);
> > Regards,
> > Christopher Schmidt
> > MetaCarta
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070404/73d87d89/attachment.html
