[OpenLayers-Users] erase drawn features
Tim Schaub noreply at geocartic.com
Fri Apr 6 12:59:56 EDT 2007
Mike Quentel wrote:
> Please, advice on implementing functionality to erase all drawn features?
All drawn features are associated with a layer.  To remove features from
a layer (which will also erase them), use:
     // given a vector layer and an array of features
     layer.removeFeatures(features);
To remove all features from a layer, you could use:
     layer.removeFeatures(layer.features);
Note that this is currently broken - and will be until the patch for
#645 is in [1].
The layer.removeFeatures method doesn't actually destroy the features
that you send it - so you could be leaking memory if you use this
regularly.  If you want to actually get rid of all the features in a
layer, use:
     // erase features and get rid of the evidence
     layer.destroyFeatures();
The one thing that is missing here is an eraseFeature or eraseFeatures
method.  This would only temporarily erase the visual representation of
the features - leaving them as part of the layer.features array.
(Perhaps this will come with 2.5.)
Let me know if that doesn't answer your question.
Tim
[1] http://trac.openlayers.org/ticket/645
