[OpenLayers-Users] Coloring feateres? Where to start...
Andrew Larcombe andrew at andrewlarcombe.co.uk
Fri Apr 13 05:29:41 EDT 2007
On 12 Apr 2007, at 17:18, Jeff Dege wrote:
> We're considering a new application that will use maps in a way
> that is
> new to us, and I was hoping people here might tell me where to start.
> Basically, it's using a map to help visualize a set of data, collected
> by region, area, whatever.
> For the sake of example, let's assume we're working on counties.
> Suppose we have a set of data that is changing continually, that is
> being rolled by by county every ten minutes.  (The underlying database
> changes constantly, but we're running a process every ten minutes that
> creates a summary dataset, grouped by county.)
> We want to display a map that shows all the counties, color-coded
> according to one of the values in the data set, and if the user
> selects
> a county, we want to display the rest of the values for that county
> in a
> div or a popup.
> Any ideas as to where to start?
I'd use the following approach:
- create a shapefile containing the outlines  of your counties along
with attribute fields representing your (numeric?) data
- set up an installation of mapserver to serve your mapdata as images
as a wms server
- set up openlayers as a wms client
- use the onmapclick event in openlayers to make a query request to
mapserver whose return can be inserted into an openlayers popup window.
That serves as an outline, hope it (or some of it) makes sense,
Regards,
Andrew
Andrew Larcombe
Freelance Geospatial, Database & Web Programming
web: http://www.andrewlarcombe.co.uk
email: andrew at andrewlarcombe.co.uk
mob: +44 (7760) 258623
icq: 306690163
