[OpenLayers-Users] Need some help with Mercator projection
Richard Vong rvong at digitalglobe.com
Wed Apr 18 12:45:01 EDT 2007
I am using a tile system similar to that used by Google Map or MS
Virtual Earth, in which the tiles are pre-built (i.e. sliced into
256x256 pixels tiles by a GIS software from a set of large images that
were projected into the Mercator-Spheroid projection). Each tile is then
identified by a column, row, and zoom value. So I built a Layer that
draws these tiles on the map and it inherits the OpenLayers.Layer.Grid
and OpenLayers.Layer.FixedZoomLevel classes. In my Layer class, I have
implemented the getLonLatFromViewPortPx() and getViewPortPxFromLonLat()
functions that basically translate a Point to a LonLat under the
Mercator projection. The Mercator projection transform is more than a
simple scaling function which involves a cosine correction for the
latitude.
The Layer works very well as expected; calling setCenter() for a desired
LonLat moves the map to the correct location without problems. However,
now I encounter a issue when I want to draw SVG polygons on top of this
Mercator projected layer. The polygons diverge from the correct location
around the edge of the map. I have located the source of the problem in
the OpenLayers.Renderer.SVG class. This class simply scales the list of
LonLat points (the vertices of the Feature, vector polygon) by the
resolution or scale of the map to obtain the viewport point to which to
draw the polygon. This operation resembles to a re-projection
transformation, but the wrong one for Mercator. I have included two
links to screenshots that show this problem:
1- Vector layer working correctly using OpenLayers' default projection
EPSG4326. Link:
http://12.25.176.42:8080/openlayers/vector4326.jpg
2- Vector layer not working over aerial imagery using Mercator
projection. Link:
http://12.25.176.42:8080/openlayers/vectorMercator.jpg
So my question is: would it be better for OpenLayers to implement a
Projection class that can abstract the conversion from viewport-px to
LonLat (and vice versa) in a more general way other the default
scaling/resolution approach integrated into the OpenLayers.Layer class?
Hence, this class can be used by the other OpenLayers tools and features
to correctly display information on the map.
Or is there any other approach to solve this problem?
Many thanks in advanced.
Richard
