[OpenLayers-Users] Zooming problems...
Erik Uzureau erik.uzureau at metacarta.com
Fri Apr 27 18:09:03 EDT 2007
I guess I can sort of see this, yes. The problem is that you've set the
maxextent on the map. The way OL works is that you cannot pan the map past
the point where the boundaries of the maxextent are at the centerpoint.
In this case, the map cannot be panned such that its center point will be
greater than 30 degrees longitude.
Hope that helps.
Erik
On 4/27/07, Francisco Domingues <fmsd91 at hotmail.com> wrote:
> Hello Erik,
> If you zoom in with the rectangle zoom into the east europe you will see
> that it zooms in to the central europe.
> Can you see that?
> Cheers!
> Francisco Domingues
> >From: "Erik Uzureau" <erik.uzureau at metacarta.com>
> >To: "Francisco Domingues" <fmsd91 at hotmail.com>
> >CC: users at openlayers.org
> >Subject: Re: [OpenLayers-Users] Zooming problems...
> >Date: Fri, 27 Apr 2007 10:56:00 -0500
> >Can you give a more detailed explanation of your problem?
> >What are the exact steps that you take (starting with loading the page)
> >What is the exact behaviour that you experience, and what is the
> >exact behaviour that you expect?
> >Erik
> >>Hello all!
> >>I have a problem in my zooming environment, when I zoom in into zones
> near
> >>the borders of the map it zooms in into the center of the map viewer. I
> >>can't find out what the problem is, but I think is something related
> with
> >>the maxExtent or resolutions!
> >>My map is here:
> >>http://terrestrial.eionet.europa.eu/Fire%20Map%20Viewer/example
> >>Thanks in advance for any solutions!
> >>Francisco Domingues
> >>_________________________________________________________________
> >>MSN Busca: fácil, rápido, direto ao ponto.  http://search.msn.com.br
> >>Users mailing list
> >>Users at openlayers.org
> >>http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20070427/2a477005/attachment.html
