[OpenLayers-Users] Image layer appears streched
Eduardo Patto Kanegae eduardo.kanegae at inflor.com.br
Mon Aug 27 14:00:44 EDT 2007
> I´m using OpenLayers 2.4 and because ArcXML will only be available at
> 2.5 release, I´m trying to pass dinamic
> generated HTTP SRC images to OpenLayers.
> The output image appears streched and not how it was originally sized.
> My code:
> szMyImageOutput = 'http://server/output/myimage.png'
> var olMapOptions = {numZoomLevels: 1};
> olMap = new OpenLayers.Map('olMap', olMapOptions);
> var layImg = new OpenLayers.Layer.Image(
>                                'The map',
>                                szMyImageOutput,
>                                new OpenLayers.Bounds(-74.99999968,
> -38.592217934, -31.040414632, 7.99999979),
>                                new OpenLayers.Size(1016, 606) );
> olMap.addLayers([layImg]);
> olMap.zoomToExtent(new OpenLayers.Bounds(-74.99999968, -38.592217934,
> -31.040414632, 7.99999979));
> But , after loading the layer, the image appears with size of 571w X
> 606h.
> Am I missing any other parameter?
> I grab the first code from
> http://www.openlayers.org/dev/examples/image-layer.html
> *Links:
- http://www.sntgeo.com.br/epk/Output_Wanted.png - the way the image
should appear
- http://www.sntgeo.com.br/epk/Output_AfterLayerAdded.png - the way the
image is appearing
> thanks in advance
Eduardo P. Kanegae
