[OpenLayers-Users] map.toJSONString, too much recursion
Tim Schaub
noreply at geocartic.com
Wed Jan 10 12:19:32 EST 2007
> okay, are there plans for adding a toJSONString function to
> the Map object in OpenLayers? Or does anyone have one lying
The WMC spec has some promise here. I've got a half baked control lying
around on the shelf that creates a WMC doc given the state of the map. The
doc is maintained as a JSON data structure that can be translated to XML.
The same control would parse WMC docs (converting the XML to JSON) and set
the map state.
If anyone is significantly motivated, this could be finished. (Decisions
would have to be made on how to extend WMC to handle OL specific stuff - but
it is set up for that.)
Tim
> Best regards,
> Bart
> Christopher Schmidt schreef:
> > On Wed, Jan 10, 2007 at 01:00:38PM +0100, Bart van den
> Eijnden (OSGIS) wrote:
> >> Hi list,
> >> I am trying to get the OpenLayers map object as a JSON
> string (using
> >> http://www.json.org/json.js), but I get too much recursion
> errors in
> >> both IE and Firefox.
> > The OpenLayers Map object has recursive references. Using
> toJSONString
> > from JSON.org will probably not work.
> > Regards,
> Bart van den Eijnden
> OSGIS, Open Source GIS
> bartvde at osgis.nl
> http://www.osgis.nl
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
