[OpenLayers-Users] different projection and units
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Jan 19 11:50:52 EST 2007
What about your map object, did you specify the projection there as well?
Example:
map = new OpenLayers.Map( $('imgMapContainer'), { controls: [], 'projection': 'EPSG:28992', 'units':'m', 'maxExtent': new OpenLayers.Bounds(-80000, 300000, 370000, 615000) , 'maxResolution':'auto'});
Best regards,
Bart
dome febbo schreef:
> Hi list,
> I need to use a WMS service with a different projection than EPSG:4236
> but the parameters are ignored and query string contain SRS=EPSG:4236
> and BBOX are in degree units.
> This is code about problem:
> var test_OL = new OpenLayers.Layer.WMS( "Test_OL",
> "http://localhost/cgi-bin/mapserv.exe?map=C:/test1_wms.map",
> {layers: 'test1', projection:
> 'EPSG:54004', units:'m'});
> map.addLayer(test_OL);
> Why OL (2.2) ignore my request?
> Best Regards,
> Domenico
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
