[OpenLayers-Users] Highlight elements
Bart van den Eijnden (OSGIS) bartvde at osgis.nl
Mon Jan 29 10:59:02 EST 2007
which OpenLayers version are you using? It depends on the version if you
need to urlencode yourself or not. See:
http://openlayers.org/pipermail/users/2007-January/000375.html
Also, if your SLD document works as a server-side style, I would ask on the
geoserver-users list why it does not work using SLD_BODY in a HTTP GET
request.
For Mapserver this works fine.
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Aitor Calero Garcia <aitor.calero at usm.es>
Naar: Bart van den Eijnden OSGIS <bartvde at osgis.nl>
Onderwerp: RE: [OpenLayers-Users] Highlight elements
Datum: 29/01/07 13:53
> &gt; Which WMS are you using?
> I am using WMS 1.1.1 with Geoserver 1.4
> &gt; Can you post the URL from the webserver's/application server's access
> log
> &gt; which includes the sld_body parameter?
> If I don't encode it, OpenLayers shows a kind of blank page, but if I
> don't it shows the initial image.
> I have attached it.
> Thanks
